movies
Vickie4
Visitor
movies
Hi i just bought a brand new Vaio 17" laptop and i am trying to get everything going i have come up against thia problem i put a movie disk in to see how a film looked but i cannot find where it is playing i went to media center it asked me if i wanted to burn a disk. I know is probably something simple but i just cannot find the program that you view your movies or bought movies on disk.
Thanks for any help
Vickie
5 REPLIES 5
anti_z
Visitor
what type of file do you have on the disc ?
Vickie4
Visitor
hi i was trying to watch or just look at chitty chitty bang bang which is a bought dvd and a home movie one cannot see or find either one
Vickie
Thalamus.
Champion
Hi Vickie,
welcome to Club VAIO.. :slight_smile:
Do you have Win DVD on your Vaio.?
If so try using that to view your DVD..
profile.country.en_TR.title
Twinsen
Visitor
Or simply open Windows Media Player, click on Library above, and at the left side of your screen choose "Unknown DVD".
profile.country.en_GB.title
veronicadeol
Visitor
There is no such program that you are trying to find on the disk that you had bought. I had too faced the same situation where I earlier bought an DVD from local store after which it displays the same error. I guess you should try started palying with VLC 8.1 that supports formats.
watch movies online without downloading
