Keys no longer repeat when held down
profile.country.en_GB.title
vicsweet
Visitor
Hi, has anyone any suggestions for fixing this. If I hold down a key on the keyboard it no longer repeats. I have tried checking software / properties and all seems ok there.
If I plug in an alternative keyboard, the repeat function works fine.
Thanks
2 REPLIES 2
Blencogo
Hi vicsweet and welcome.
What Vaio model do you have and which Version of Windows are you using?
It could be a few things.
First thing to try is to check FilterKeys is deactivated in Control Panel -> Ease of Access -> Ease of Access Center -> Make the Keyboard Easier to Use.
Check Filter Keys is turned OFF.
:wink:
vicsweet
Visitor
Thanks Blencogo. I had checked that - they are off. Oddly though, when I went to 'double check' it on seeing your reply, when I played with setting timing on repeat keys, if I tried it out in the 'test' box, keys held down do repeat. But they still don't when I'm typing anywhere else :slight_frown:
The Vaio is VPCEH1L8E and I'm using Windows 7. I've had both for some time and this problem has only just started.
