HOW DO CHANGE SIGNING PROCEDURE ON PREFER GO STRAIGHT INTO DESKTOP
SOLVED
profile.country.en_GB.title
BWEP26
Visitor
VPCEJ
EXTRA STEP OF HAVING TO CLICK ON NAME ON SCREEN SEEMS UNNECESSARY
WOULD PREFER  FOR SYSTEM TO OPEN DIRECTLY INTO DESKTOP
THANK YOU
BARRIE  alias  BWEP26
Tags (4)
1 ACCEPTED SOLUTION
Accepted Solutions
Blencogo
Hi Barrie,
Have a look at this tutorial: -
http://www.sevenforums.com/tutorials/377-log-automatically-startup.html
If you only have one user registered on the computer and that user is not password protected, Windows will automatically log on to that account at startup.
If you have more than one user registered on the Vaio, you can choose for Windows to log in the account of your choice by removing the check box 'Users must enter a user name and password to use this computer'.
:wink:
2 REPLIES 2
Blencogo
Hi Barrie,
:wink:
danhague
Visitor
Good luck on this bud. I checked the steps. It will just be a walk in the park for you. http://imagicon.info/cat/12-13/vbulletin-smile.gif
