Could any Techies please help. I recently purchased my subscription from http://www.tvtv.co.uk to use with my Network Media Receiver - the bit I dont understand is where to put all the additional channels in the Tuner section of Gigapocket. I thought I had it but last nights recording was C5 and not the channel I thought I was downloading.
Any suggestions folks?
Emails gratefully accepted!
Regards
Dave
I don't have giga pocket so can't help. Just wanted to say I like the avatar :smileygrin:
Thanks - maybe when I get more time I'll do an animation like yours
Dave
I don't have giga pocket so can't help. Just wanted to say I like the avatar :smileygrin:Hiya Dave, glad you made it :smileygrin: But you do realise you have now fallen drastically in my ratings, nearly as low as young tellingd here:smileylaugh: There is only one true Birmingham team:smileytongue::smileylaugh:
Davenash,
Just a little confused: you wanted to record a program on C5, but got another channel ?
I would redownload the list from that website.
Are you sure Gigapocket is compatible with it?
Yes it appears to be - according to Sony anyway - the problem seems to stem from needing to introduce network channels into Gigapocket. £15 wasted I suppose?
Dave
Mmmmm let me think................... Oh yeah 5th wernt we?:smileycry:
July 2 2004.
Dave if it doesn't work then I would ask for a refund - or some good support on their side.
Thanks - Ill take a look - and post results.
Dave:smileygrin:
