FZ11Z complete factory settings question
DrContinental
Visitor
Hi there.
Ive had my vaio for over a year now.Its an f11z.Im not expert by any means but the time has come for a factory reset.I understand i will lose all of my files and so on, but will i lose the software it came pre loaded with?
Since i have no disks with it to reinstall from i dont want to lose programmes like the blu ray programmes and so on.
How should i go about my factory reset? Since i have only done this on a desktop with the necessary disks?
Help would be greatly appreciated.
1 REPLY 1
Thalamus.
Champion
Hi DrContinental,
the Vaio Recovery Utility will return your Vaio to the original 'As new' state, this includes the Vista operating system and the pre-installed applications.. :slight_smile:
Click Start, All Programs, then Vaio Recovery Tool and finally Vaio Recovery Utility..
Click Continue on the User Account Control window
Once the Vaio Recovery Center window opens
Select Restore C: Drive then press Start..
then follow the recovery wizard..
There is a guide on the Recovery procedure for your FZ11Z should you need it, use the following link: Recovery Guide
