FX702 LCD screen died
alphadot
Visitor
Hi Folks,
The LCD screen on my FX702 has died. There is no sign of damage to the display, but it just glows a very dull white 😞
I am still able to us the laptop on an external monitor.
Does anyone have any suggestion, or experience on getting such faults fixed here in the UK?
Many thanks for your help.
Conway
2 REPLIES 2
profile.country.en_GB.title
kee-lo_
Member
Hi Conway,
It's not a cheap procedure, if it's the LCD then it's expensive to get the replacement but easy to fit, but if it's the inverter it's not as easy to fit, but costs less than the LCD.
Taking it to a laptop specialist might be the best thing to do.
grahambird80
Visitor
It should still work throught a monitor.
It could be that the cable that runs from the main unit to the screen has worn out.
I would go with Kee-lo's suggestion take it to a computer repair company. Check with your local resellers to se if they have any suggestions.
