Fn Keys Not Working In Win XP Pro
fas
Visitor
SONY VAIO MODEL PCG-GRZ515G AFTER INSTALLING WINDOWS XP PRO FUCTION KEYS ARE NOT WORKING AT ALL.
3 REPLIES 3
JoeB.
Visitor
be sure the utilities are installed... found von vaio-link.com
Matti84
Visitor
there the same problem by me. i cant mute the sound or raise the volume. i can activate the stand by modus be the FN Key - but als the other combination don´t work!!!!
grahambird80
Visitor
Also check that you have the buttons configured correctly in the hotkey utility (if your laptop have one).
