Fingerprints...
insanity
Visitor
Fingerprints...
This might sound like a daft question, but what's the best way to get rid of fingerprints from your screen?
I've had my TR5MP for a couple of weeks now, and despite my best efforts I've ended up with fingerprints on the screen. Now, the screen is lovely (being one of this new x-black types), but fingerprints kinda show up.
The manual says to use a soft dry cloth, but that doesn't work too well. I don't want to use any of these screenwipe products as I'm a bit dubious about them... so what's the best way of cleaning up my screen?
7 REPLIES 7
profile.country.en_GB.title
kee-lo_
Member
Try a slightly wet lint free cloth.
Not too much water mind you. Wring it out.
JoeB.
Visitor
Yes... water works fine... yet i use warm water and only do small areas at a time... never wipe the hole screen at once...
kee-lo_
Member
Big streaks :slight_frown:
insanity
Visitor
Cheers.
I'll never forget a mate of mine who used some cleaner spray on his Iiyama TFT - totally trashed whatever coating is (or was!) on it, and (of course) Iiyama refused to repair/replace it... :cry:
kee-lo_
Member
You have to use a product without alcohol.
JoeB.
Visitor
if you are useing any type of cleaning fluids.... make shure that it does not contain any kind of amonia... cause that stuff eats your tft surface right up... i have use glas cleaner without amonia on my display with no damage....
joe
kee-lo_
Member
Yeah amonia is bad for LCDs and TFTs
