Hi all,
How are ya? I bought my VAIO AR31E 5 months ago. It's running nicely up to now, no problems so far except sometime with reading some memory cards.
Anyway, my problem started from 2 days, maybe after installing some updates. My CTRL key isn't working anymore as if to use as a combination key (CTRL+V, to paste), its happening with all other keys.
I'll be glad and thankful to find a solution
. Thanks.
Hi hunch,
what updates did you install.?
Simple solution would be to try a system restore to a point before you installed the updates..
Does that solve the problem, if not let us know.?
Go to device manager then expand keyboards are there any warning icons.?
Hi hunch,
