DL standard that my Writer Supports
Icarus99
Visitor
Hi All
I have a Sony Vaio SZ2 XP/C and I want to know which DL DVD write standard it supports. The Sony Support Website says its Dual Layer write but my documentation installed on laptop says its Double Layer write. I have tried Double layer and it sometimes works and sometimes doesnt which does not really tell me definitively :thinking:
DVD Model Matshita UJ-832D
Driver Date 01/07/2001
Driver Version 5.1.2535.0
Regards
Icarus99
4 REPLIES 4
Thalamus.
Champion
Hi Icarus99,
as far as I am aware Dual Layer write and Double Layer write are the same..
Your drive can support DVD DL burning at a write speed of 2.4 x although this can be less..
What brand of disc's are you using.?
Verbatim are a popular choice.. :slight_smile:
Icarus99
Visitor
HI
From what I have seen writers tend to support one or the other not both and i was getting different answers depending on where I looked. Anotyher possibility is that my dvd burning software doesnt like the standard much as I got a lot of failures when trying with double layer media. It did work occasionally with no problems, its a bit like the problems that used to happen with CD writing before cacheing came along sometimes it would work sometimes it would throw up a fault and you have to start again.
If i need to burn large media sizes again I will try dual layer and see what happens. :slight_smile:
Cheers
Icarus99
Thalamus.
Champion
Hi Icarus99,
on checking further it seems as though DVD-R DL discs are referred to as dual layer and DVD+R DL are referred to as double layer..
Therefore your SZ should be able to burn DVD+R DL (double layer) at x2.4 speed.
What make and type of media are you using at the moment.?
Icarus99
Visitor
Hi
I was using Phillips, luckily I dont have to burn over 4.5gb very often so its no major problem. The results just seemed very random. I tried Nero and Roxio with what seems to be random results, sometimes it works sometimes it doesnt.
Its no big deal though. :slight_smile:
Icarus99
