bluetooth?????
mangalore
Visitor
bluetooth?????
Hi,
I just bought a VAIO VGN-A195EP, and i have read on the specifications that this model has bluetooth... how do i use it???
Help please...:smileycry:
3 REPLIES 3
grahambird80
Visitor
Is there a specific device you want to use with the computer.
There should be a program called Blue Space i think that you use to descover other bluetooth devices.
As to how it works
Turn the bluetooth on on your laptop,
Turn the bluetooth on you other device (say a moblie) set to descoverabule
On the laptop use the bluetooth software to search for other devices.
It should find the other device.
Now you need to set up a partnership with the devices.
The bluetooth software will ask you to input a pass key (this is just a 4 digit pin number say 1234)
The phone will the recieve the request to partnership and ask for the passkey (1234) enter it and the two devices should be pared.
From here the software should locate the services that the phone offers, for example if the phone is a camera phone there should be file pushing, this allows you to transfer files between the phone and computer. Other services could be serial connection, modem etc...
Hope this helps.
mangalore
Visitor
Thank you for your answer, but the is that i cant find blue space in my computer... is that possible????????
Psaila
Visitor
Hi Mangalor.
Hit This link to find " BLUETOOTH MANUALS "
" This manual will guide you through the wireless possibilities of the Bluetooth¿ function on your Sony devices. The chapters describe how to configure your Sony Ericsson mobile phone, your Sony CLIÉ handheld and Sony VAIO computer, using the BlueSpace NE software with Windows® XP, for optimum use of wireless connectivity with Bluetooth¿. " CLUB VAIO
