BLUE SCREEN FATAL SYSTEM ERROR c000021a, any help please?
profile.country.en_GB.title
VIOREL33
Visitor
i have a sony vaio VGN-FW21L. it crashes from time to time and when i power it, a blue screen appears with the folowing: FATAL SYSTEM ERROR  c000021a
can anybody help please? what shall i do?
4 REPLIES 4
Blencogo
Hi VIOREL33.
I don't think there is a simple answer.  You can try the troubleshooting steps in this Microsoft Answers link: -
http://answers.microsoft.com/en-us/windows/forum/windows_vista-system/vista-c000021a-fatal-system-er...
Unfortunately, there are quite a few things to try!
Are there any other messages on the blue screen that may help narrow the field?  What are you running when it crashes?  Does the Vaio get hot before crashing?
:thinking:
flogger12345
Visitor
Hi Viorel. Sometimes its a memory issue. Try to unplug and replug your RAM stick. Hope it helps. http://imagicon.info/cat/12-13/vbulletin-smile.gif
VIOREL33
Visitor
thank you for your help and time!
VIOREL33
Visitor
thank you very much for your help, I will try my best!
