Blue Ray
profile.country.el_GR.title
chrmorai
Visitor
Blue Ray
I lost the driver of Blue Ray of my Vaio when i was installing windows 7. Now i can't play BlueRay DVD.
1 REPLY 1
rich912
Contributor
Hi chrmoral,
I think that you will find you have lost the software that plays Blue-Ray rather than the driver.
If you carried out a clean install of Win 7, as opposed to an in-place upgrade, you will have lost the preinstalled software.
You have the option to return your notebook to factory settings and then carry out an in-place upgrade which will retain all preinstalled software, drivers and utilities or purchace software such as Win DVD BD.
Rich
Go n-éirí an bóthar leat
