AR21S Screen Inverter
prednisolon
Visitor
Hi All,
Where can I buy a AR21S Screen Inverter? And anybody knows a website that tells you how to do it?
Sony 1-813-789-11 Inverter
Cheers,
ALi
3 REPLIES 3
Thalamus.
Champion
Hi ALi,
have a look at nexttronics, they are a US based company but they state that they ship worldwide..
Use the following link to view the: AR21S part list
I have sent you a Private Message, use the following link to view your messages: Private Messages
prednisolon
Visitor
Hi ALi,
Thanks. Ive bought a brand new inverter and still the same problem. Im guessing, one of the cables from the case goes to the screen is dead or the screen itself. Though its very unlikely as there are no damages done to the screen at all.
Any suggestions?
Thalamus.
Champion
Hi prednisolon,
it could be a number of things...
faulty cable, faulty connection, backlight bulb, etc..
May be worth taking your Vaio to a good local repairer and for a diagnostic and quote for repair..
