Wireless PS3 gaming using WI-FI dongle
SOLVED
profile.country.en_GB.title
joemalo
Visitor
I've just bought a KDL-40EX723 tv and the UWA-BR100 Wi-fi dongle that accompanies it. Was hoping to play my PS3 games through the TV but because the PS3 is in another room I need to do it wirelessly. Is this possible? If so, how do i set it up?
Thanks
1 ACCEPTED SOLUTION
Accepted Solutions
Catmambo
Contributor
Hi
No the wireless dongle will allow you to connect your TV to the Internet and access video services etc, you can't use it to create a P2P connection with your PS3. You'd need some kind of wirelss HDMI sender for that.
Thanks
1 REPLY 1
Catmambo
Contributor
Hi
Thanks
