Sound levels on KDL37EX723
SOLVED
profile.country.en_GB.title
elmstone
Visitor
I have a Bravia KDL37EX723 connected by an HDMI cable to a Virgin+ box.  Everything works well but when watching HDTV channels I have to considerably  increase the volume; when switching back to standard channels  the volume must be reduced again. I have looked at the answer to a similar problem with a home cinema setup using a KDL40HX723 but I can't find the advanced auto settings tab mentioned there.
Is there a way of balancing these levels in my system?
1 ACCEPTED SOLUTION
Accepted Solutions
Thalamus.
Champion
Hi elmstone,
welcome to Questions & Answers..:smileyhappy:
Does the solution in the following thread help..:smileyconfused: - sound output when connected to a  sky + HD box is very poor and has to be set very loud with the vol...
3 REPLIES 3
Thalamus.
Champion
Hi elmstone,
elmstone
Visitor
Thank you, that seems to have worked, I will see how it goes but now I know how I can go back and readjust the level of offset if necessary.  Also, using that menu I was able to find the auto adjustment control and turn that on and so that may have helped too.
Thalamus.
Champion
You're welcome elmstone..:smileyhappy:
