Sony Bravia LDL40EX724
profile.country.en_GB.title
sagar1945
Visitor
I have recently purchase above model TV. I want to connect my PC (which is in other room upstairs) and TV is in seating room. My TV is internal built Wi-Fi. I can see my some of picture which is JPG and some of not which is JPG. Also I want to connect my PC and TV via Wife so that I can see my desktop so that without changing my picture file format to JPG can be seeing on TV.
Please tell me how can I do this?
Tags (2)
1 REPLY 1
65hx923_cust11
Explorer
It is a bit confusing what you want, sorry if this does not answer your question.
If you want to see your desktop on your TV, you will need to connect the PC and the TV directly. Either use the PC input on your TV or a HDMI cable if your PC has HDMI video output. The PC and the TV must be in the same room close to each other unless you have a seriously large cable. This cannot be done via Wi-Fi
If you want to browse media files from your PC with your TV, then you will to install a media server on your PC, you will not be able to see the desktop but you will be able to browse pictures, videos and pictures. This can be done using Wi-Fi. The TV and PC can be far apart but within Wi-Fi range. For media server try this one: http://www.serviio.org/
Hope this help
