Sony Bravia KD-49XE7077 and does not working external subtitles via DLNA
profile.country.CZ.title
faladorcz
New
Hello,
I bought Bravia KD-49XE7077 and now I am solving this issue.
Iam using Zyxel NSA 310 - media server Twonky
If I connect with TV to media server I can play a MKV movie but I can not see external subtitles.
SRT subtitles and MKV movie have the same name and are in the same folder.
Anyone know how to fix it?
Thanks a lot!
4 REPLIES 4
cass_n
Hi @faladorcz, welcome to the community :slight_smile:
Are the subtitles saved in UTF-8 format?  If not, try saving them in this format and see if that works.
Cheers,
Cass
Manu_T
Member
Perhaps you can use another DLNA server.
I've been using Universal Media Server (UMS) for awhile now and I can wholeheartly recommend it. This is a JAVA written application so perhaps it is available for your NAS too.
I use it as an application on a Windows PC.
UMS transcode files with subtitles. I've used it successfully with Sony W8xxB-series, LG 65EG960V (some large Oled TV) and various Samsung TV's. Since version 6.7.1 it also works with very well with Android-smartphones and tablets (transcoding video with subtitles).
Perhaps this is off any use.
Regards,
Manu T
faladorcz
New
Hi,
thanks for answer but it did not help. When the mkv movie is playing I am not able to add subtitles with a button on a controller.
faladorcz
New
I can not use another media server my NAS Zyxel only supports Twonky media server.
