I need to know all the settings I should put on for my ps4 pro to be used to the best quality, i am not too sure how to get it perfect, I have it in hdmi enhanced etc but want to know the exact best settings to get the best quality for the ps4 pro? Thanks
Hi there. Your console will auto select the best settings for your TV. You might also want to check if there's a 'game mode' or similar in your settings on the TV itself? Hope this helps.
Thanks,
Owen
