pin required
SOLVED
INKY2U
Explorer
pin required
trying to setup my tv get past wps then it ask for a pin
how do i obtain a 4digit pin ?
anyhelp please
2 ACCEPTED SOLUTIONS
Accepted Solutions
EdwinaU
Hi there,
Can you tell us the model number of your TV and explain what you are trying to set up?
Thanks,
Ed
INKY2U
Explorer
Sorry for delaying reply not been too well I solved PIN number I’d been entering wrong number many thanks for you 3ven replying to me once again many thanks
2 REPLIES 2
EdwinaU
Hi there,
Thanks,
Ed
INKY2U
Explorer
