No sound through TV after connecting Blu-Ray player BDP-S3100
SOLVED
MLD1973
New
Hi
We've purchased a sony BDP-S3100 today and thought it would be easy to connect to our Sony Bravia TV (KDL-37S5500). We've plugged the HDMI cable in to HDMI 1, and have amazing picture but sadly no sounds. Have tried various things from the set up however still nothing. Any advice would be greatly appreciated.
1 ACCEPTED SOLUTION
Accepted Solutions
Anonymous
Not applicable
Hi there
It should work, theres not that many setting to change really.
On the bluray player:
  • Under audio settings, ensure that Digital Audio Out is set to Auto, and try setting Downmix to Stereo
  • Turn on Control for HDMI under HDMI Settings
On the TV:
  • In Sound Adjustment Settings > Speakers, ensure that its set to "TV Speaker"
If that still fails - Try turning OFF the TV and Bluray player from the powerpoint on the wall.  Leave off for 2 minutes, and switch it all on again, starting with TV first.
Hope that helps.
3 REPLIES 3
Anonymous
Not applicable
Hi there
On the TV:
Hope that helps.
MLD1973
New
Thank you so much it's working fine now. Merry Christmas
Paliubomu
New
@Anonymous wrote:
Hi there
On the TV:
Hope that helps.
My one 5.1 system doesn’t have sound from surround and center speakers, subwoofer and front speakers works good.i tried different set up components and its same.  Any ideas?
