KDL-48WD653 bootloops on HD channels
Ginger_NutZ
Explorer
everything was fine untill yesterday. Auto download is enabled, current firmware is 8.211-1000-1.33-01. I thought it might have been corrupted firmware so downloaded current and TV cannot find new software as current and update file on USB are the same.  Dont really want to hard reset the TV as current settings were made 18 months ago and I'm sure I wont be able to remember how I had it set up.
Is there a way to backport to previous firmware?
1 REPLY 1
EdwinaU
Hi there,
Welcome to the community. Sorry to hear you're having issues since updating, I'll let the team know you're looking for help. Meanwhile, you'll find some Q&A's and update information for your TV here.
Thanks,
EdwinaU
