I bought three Sony TVs between June 2015 to Oct 2016 1 regular and 2 Android. The first one and least used simply will not power up, no LED no life whatsoever. TV had not bee used for a weeks or so and I assumed maybe something wrong with power. So checked the power socket and it's OK. Checked the 3AMP fuse in the plug and it's OK. Brought the power cable (laptop type ACDP-100D01) back to retailer and asked to check it. They said it seemed to be power unit and to contact Sony.
I recieved cryptic info from Sony about 5 year waranty and was told to check this. I understand now that there is no 5 year waranty on this TV, so next step repair or replace part.
Problem is I cant get clear information about th product I need. The part number is 149292612 19.5V ACDP-100D01 but I am finding difficulty finding this. I assume similar adaptors are available but I want to be sure.
Can anyone help. I am in Ireland.
Solved! Go to Solution.
Hi @orwell84,
I had a look on EET Europarts for you and found 3 power chargers listed against your TV: https://uk.eetgroup.com/Guides/Sony/m/Sony-LCD-Television-41-46-inch-KDL-42W815B?c=800101
I hope this helps?
Cheers,
C
Hi @orwell84,
I hope this helps?
Cheers,
C
