KDL 40EX720 BAEP recording HD or SD?
profile.country.ro_RO.title
eddyiek
Visitor
Hi,
I was wondering about the quality of the recordings for a KDL 40EX720. If you perform a recording from a HD source, say an HD channel via the DVB-C tuner, is the recording still HD quality or SD?
Also, has anyone tried to partition the external HDD so that you are able to use one partition registered with the TV and the other by a regular PC? I mean, does the TV recognize the HDD's partitioning so that it would allow only for a selected partition to be registered while leaving the other partition(s) untouched?
Thanks in advance
1 REPLY 1
profile.country.hu_HU.title
1orrsi
Visitor
Yes, recording will be in HD.
It is not possible to partition, it wont work.
