Hi everyone,
I have had problem with my Sony TV since I updated it on new Firmware v8.885.
I have Sony KD-43XE7077 and after update I can't open Netflix and DW?
Does anybody know how to fix that or is there possibility to go back at an old version of Firmware?
Thanks
Hi,
Please refresh internet content via network menu - this should solve the issue.
Cheers
Peter
Hi,
I tried and unfortunately it has worked partially. The DW works now but Netflix I still can't open.
Thanks for advise anyway.
Do you get a specific error message or code when you start Netflix? Does the app crash? tell us more.
Win_88
I am sorry for not describing more. 😞
There is no code or message. When I try to open I barely can see log in and app just crash.
Thanks for traying to help.
Try a power cycle first, but if the issue remains, try connecting the TV to a WiFi hotspot to check if the same happens on a different network connection (make sure the phone used for tethering is on 4G as opposed to your home Wi-Fi)
Win_88
Hi,
Thanks for advise, unfortunately didn't help. The power cycle helps only for first time using Netflix. When I want to start Netflix the second time I have the same problem, app crash. I also tried to connect my TV to another WiFi hotspot , the result is the same. So power cycle works partly.
it's not possible to revert to older software versions. I'd recommend resetting the TV to factory settings.
Win_88
I have tried that too.... Same thing.
How to upload video here?
The easiest way is to upload it to Youtube and post the link here
