Hi!
Im planning to put my tv inwall, the "hole" will be 146cm wide X 100cm height and 14cm deep
Is it okay yo put my KDL-60ex700 in that?
Thinking about if that space is to small to put my tv in?
It might get to warm?
Does the Tv turn off if it gets to warm? (Selfprotect)
Best Regards
Henrik
Message was edited by: henrik_axen
If is wall flat, there is no problem, but to put in 14 cm hole, I will NOT recommand.
There are standards, some of tham described in instruction manual on begining, by wall mount.
TV has to have speace for warm air comming out from TV, especially on top of TV.
I recommand flat wall with speace around.
Regards
Damac
Do not count on selfprotection of TV in this case. It is for something else.
