How to Remove 3D Dual screen
SOLVED
profile.country.en_IE.title
ko1257
Visitor
How do i remove the dual screen when watching 3D tv . Once i access the 3D menu. I have a choice of Simulated 3D or Off . The on tab is missing Im using Bravia 46HX803
1 ACCEPTED SOLUTION
Accepted Solutions
profile.country.en_GB.title
Catmambo
Contributor
Dual screens basically means that the input signal that is being received is in 'side by side' mode - so you would need to change to 'side by side' to get the TV to display them properly. To turn it off, just switch 3D off..
Thanks
1 REPLY 1
Catmambo
Contributor
Thanks
