hdmi banner stuck
martinwafc
Explorer
hdmi banner stuck
Hdmi info stuck on screen
Sony bravia KDL32U2000
CANT FIND REMOTE SO NO IDEA HOW TO GET RID OF IT..
ANY HELP MASSIVELY APPRECIATED.
4 REPLIES 4
Pascale_F
Hi Martin,
I'll see if I can find this out for you. Maybe someone else in the community can help in the meantime.
Thanks,
Pascale
martinwafc
Explorer
Thank you greatly appreciate it.
The_Black_Rose
Specialist
Hi martinwafc,
There should be an i+ button on the remote control, if you press on it, the information banner should disappear.
You can find the location and functions of the buttons on the remote control on page 10 of the manual here: http://bit.ly/2XnNXQ3.
Cheers,
The_Black_Rose
martinwafc
Explorer
Nopem massive problem is i cant find the remote anywhere. Tried using the buttons and going into the settings but nothing there.
I programmed my sky remote to it but nothing on that to fix it. Just have buy a replacement remote.
