- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
i have the ex720 bravia set with a rm-ed044 remote. I have set up the tv to have control of the ps3 via HDMI using the tv remote. It works, however there doesnt seem to be a 'select' button equivalent.
where can i find out what button does what? Or perhaps is there a way to add functions to the remote? Or is there an updatw needed perhaps. It seems such a shame that can use the tv remote for everything, but as soon as i need to press 'select' i need to turn on the ps3 controller to do so.
im not expecting any positive response, but im so happy i could control the ps3 with my tv remote, im just checking there isnt something i hadnt thought of.
... for a second question, is it possible to set a bravia tv t NOT remember which input was last being used when it was switched off? Id love the TV to always default back to 'TV' mode rather than HDMI1 - girlfriend gets confused how to switch back to TV mode
Any kind remarks welcome
thanks
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi,
You did not mentioned the full model number but it is not an issue
To find what button do what? read the i-manual http://support.sony-europe.com/tvhc/tv/lcd/lcd.aspx?site=odw_en_GB&m=KDL-40EX720
To make the TV always switched ON to TV Channel rather than HDMI, simply press any number 1,2,...9 on your remote back from switched OFF state
Regards
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi,
Regards
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
thanks for the tip with using the numbers to quickly revert backto TV mode... obvious in hind-sight
as for the i-manual... this does not list what buttons operate the ps3 on my tv remote.
