Connecting tv to router
SOLVED
profile.country.en_GB.title
mattla
Visitor
I want to connect my ex503 tv to my router using an ethernet cable.  Do I need to purchase a 'high speed cable' or will a standard one work just as well?
1 ACCEPTED SOLUTION
Accepted Solutions
Bravia55HX
Member
Hi,
a standard one will work fine.
regards
2 REPLIES 2
Bravia55HX
Member
Hi,
regards
mattla
Visitor
Thanks for your advice.
Matt
