Bravia TV youtube constant loading and blurry
Taraborn
New
On the Netflix app on the TV I get perfect picture quality amd connection, and when I first got the TV the same was on YouTube. Barely a week later amd YouTube is pretty much unworkable. I get 2 minutes of decent quality picture and then it goes to very blurry and then eventually will come up with it saying it is loading and then will just cut out.
Any fixes?
1 REPLY 1
Mick_D
Hi @Taraborn, welcome to the Community.
Can you confirm the TV's firmware is up to date? If you can provide the model number that would also help identify the problem.
It's also worth doing a reset to see if that clears the problem.
Cheers
Mick
