Bravia TV Home button not working?
JayPDC
Explorer
Hello, I was wondering if anyone knows why the Home button on my Sony Bravia TV remote no longer seems to work?
It used to bring up my options for apps and YouTube etc, but doesn't seem to be working now?
I have my TV linked to a Sky+ Box and the TV is less than a year old.
Any help appreciated.
Thanks!
Tags (3)
21 REPLIES 21
lindilou
Explorer
my home button stopped working after the last up date what can be done to get it back?
lindilou
Explorer
Sorry meant to add, I don’t have sky or any other device only dvd.
lindilou
Explorer
I don’t have sky but my home button stopped working after the last update, what can be done? Any help appreciated.
ally.zaman
New
Hi
I just switched off BRAVIA Sync Control and everything back to normal.
Go to TV mode. Press Home > Settings > system settings > setup > BRAVIA Sync Settings > BRAVIA Sync Control > Off
boug1966
Explorer
The problem with your solution is you say press home>settings etc. Well as it says in the question 'home button does not work' so this won't help.
Has anyone found a way to get the home button working yet all I can find is a way to get iplayer etc using youview then blue button for players but no way to get into setting etc
Cannot upgrade the software as the Home button is needed
Tried disabling HDMI CEC no difference
Looks like some update has bricked the TV
sb_fung
New
did you ever get your home button to work?
This suxxxxxxx!...I do have a dennon audio reciever that has a hdmi control
D3bbyp
New
Has anyone had any success in getting the home button to work? I don’t have Sky and wondered how to resolve this issue?
LightFoot
Specialist
Hi @D3bbyp
I would give Sony a call. The last time it happened to me a couple of years ago they simply asked me to key a sequence of keys on the remote to get it to work. https://services.sony.co.uk/supportmvc/en/Contact/Email
I had this issue last night and as you say how can you do anything without the home button!
in the end I did a factory reset. Press the help button and from there go to using my tv, settings and from there you will be able to navigate to storage and data. I did a factory reset. ( takes a while) now everything is back to new and all works
soulmonkeylove
Explorer
I had this problem for years and found that to enter the home screen I had to press the button at the top left of my Sony remote to show the input options, at which point as a result of entering the TV navigation the home button would work.
