BRAVIA KDL-32EX523 - power led blinking 8 tmes per sequence of blinking
SOLVED
profile.country.en_GB.title
gilbertoborges
Visitor
BRAVIA  KDL-32EX523 - power led blinking 8 tmes per sequence of blinking - what is goin on?
1 ACCEPTED SOLUTION
Accepted Solutions
Bravia55HX
Member
Hi,
it appears you have a fault code stored in the tv' and will require a Sony service tech to look at it.
2 REPLIES 2
Bravia55HX
Member
Hi,
Bravia55HX
Member
Hi again,
have you done anything about your problem yet?,
i can tell you its down to an Audio fault so with any luck a repair should not be expensive.
