Advanced Technical Specs for Sony TV
profile.country.en_GB.title
KDL-CX520
Visitor
Hi
I am looking for more detailed specs of my Sony KDL-32CX520. because it is not mentioned under the product page
1- What type of panel used? is it S-PVA or another.
2- The panel (pixel) response time in (ms) (note: 2006 MY were 8ms as example)
3- Dynamic Contrast ratio or Image Contrast ratio.
With Thanks
2 REPLIES 2
KDL-CX520
Visitor
Hi again,
I don't know if my english is good or so bad , if my question above need more explanation in english please let me know :wink:
Catmambo and Sony Forum moderators , Kindly advise by any answer by yes or no.
Appreciate your support to me as a Sony customer.
Regards
-Cass-
Explorer
Hi KDL-CX520,
To better your chances of an answer to your problem, it would be best if you address your question to all members of the Sony community on the site to improve your chances of finding a solution.
Failing that, if you the community are unable to help, you may wish to contact Sony Support directly for further help.
Good luck!
Kind regards
Lisa
