Don't panic, go step by step.
Problem still there?
The support app is great for help and finding the possibilities of your device.
Hi Strampke,
Thanks for the helpful post!
Here's a nice video that helps you to troubleshoot your mobile:
Cheers
Peter
If you own an Xperia, it's not surprising that it occasionally has problems; it happens with all phones. I usually start with simple things without panicking. First, I restart the phone; strangely enough, most problems are fixed that way. If it doesn't, I check for updates; sometimes even a small software update brings the phone back to life.
