i lost 3G coverage after upgrading my Xperia Tx to JB
SOLVED
Dodger86
Visitor
HIiii
i unboxed Xperia Tx with ICS 4.0.4 , i used a gsm sim.. it was OK, then i used a 3G sim, and it also was OK
after upgrading To JB 4.1.2, gsm sim still working Ok, but when i use the 3G sim i dnt get any coverage at all, just like the phone is not reading th sim card ... how can i fix it ??
1 ACCEPTED SOLUTION
Accepted Solutions
Dodger86
Visitor
HI .. i SOLVED the problem
check the pic attached.......
when i bought the phone, i was using SIM card number 1 on ICS 4.0.4 .. 3g was working with full coverage
after upgrading to JB 4.1.2, SIM card number 1 is not working any more because it's not compatible with JB 4.1.2 .. so 3G was not working anymore, and there was no 3G coverage at all
i went to the GSM company, and they gave me SIM card number 2, which is compatible with JB 4.1.2
7 REPLIES 7
Uliwooly
double check the APN settings also if it might be a faulty SIM card or it could be an intrusive app acting up
taskillers
task managers
antivirus
uninstall them > restart your phone and check again
Don't forget to mark the Correct Answers & Helpful Answers
Dodger86
Visitor
i can't get APN settings because there's no 3G coverage to recieve the settings
SIM card works on other 3g devices and modems
no programs installed on phone ..
3G was working on phone before upgrade .. so it's not a hardware problem
dnno wt to do !!
Uliwooly
who is your carrier and which country?
Uliwooly
enter them manually
settings > more > mobile networks > access point names > menu > add New > enter the info > menu > save
Dodger86
Visitor
Uliwooly
yeah, I've seen that many times and some users don't believe me when I say that the SIM card could cause certain issues
Dodger86
Visitor
and i can confirm that .. thank you
