is there any way to delete the whole conversation you have had with someone?
its pretty frustrating to have to go into a conversation and delete a whole bunch of messages one by one.
Solved! Go to Solution.
Open the message application. Press the menu button. In the option you can see delete several. Select the option and check the message that you want to delete and press delete button on top right.
Use HandcentSMS application to get numerous features. Available free on Market.
thankyou
