Hi,
I have not being having a battery problem with my Arc since i bought it in Sep 2011. I keep it updated & everything. I updated it recently to the 4.xxx.62 update. Today, i was playing PINBALL Deluxe as usual when my battery level was close to 25%. Just two mins. in the game, I got the Low battery level popup showing the current level as 1% and the phone got turned off.
I was freaked out a litlle, but I whipped out the charger & started charging again. When the fone started, it showed the Battery level up to 26%
I unplugged the charger, & kept the phone as it is on standby (Brightness - 25%, Data - off, No apps running)
But again in 5 mins, the popup appeared indicating my battery level to 1%.
I am not sure why or how this is happening. The phone is still in warranty & the battery definitely hasn't gone bad. Please help me.
Specs:
Model: LT15i
OS: 2.3.4
Kernel: 2.6.32.9-perf
SEMCUser@SEMCHost#1
Build no: 4.0.2.A.0.62
Solved! Go to Solution.
Just popping in here to let you know I've read all comments and that I'm keeping an eye on this.
Please keep the discussion going and update any progress on this.
Thanks for helping out nabeelraza and slim. Highly appreciated. :smileyplus:
thanks 🙂
look at this thread also ,
http://talk.sonymobile.com/message/163421#163421
i have explained in that thread...
and yes i'll keep an eye on this thread for your feedback 😉
Thanks Slimshaddy & nabeelraza. The problem has been sorted out.
thanks a lot MARKUS
the problem is solved
and Anshul, great, enjoy
great
Hi ,
Am also feel the same after 4.xxx.62 update. Today am going to try this ....
hmm keep us updated
I am also facing the same issue and tried doing this all, but of no use.... Can you suggest what further needs to be done....
Go for a software repair
