So with SE seemingly not giving x10 mini the 2.2 upgrade, is there anywhere i can get flash player. Generally i am happy with the phone on 2.1 I can do everything i want to do. But I could really use the flash player. Anyone got ideas???
Solved! Go to Solution.
I I understand, I am also caution on what I 'feed' my phone
The answer to all your questions is yes! (you seems to know the answer) 😛
In fact, you can manually tap on either brower icons to start it up. Just uninstall it if you don't like it
Adobe flash player is not supported by Android 2.1, only by the 2.2
You should be interested in this, http://www.skyfire.com/en/product/android
It's a free web browser available in the Market, take your time to explore it!
OK
If I downloaded that I would lose most of my internet settings yes?
Yes and no. Your internet settings are still saved in your default browser. You will have the choice to select either one for surfing. Just make sure you don't set Skyfire as your default browser (your choice if preferred).
So the two can be run side by side... I would get the option at the browser start up which one to start?
Its available from android market on phone yes? search sky fire i presume?
Sorry for all the questions, I just want to make sure what i install is ok.
Many thanks for your help i will download it now and let you all know how it goes :smileygrin:
