Oppsttttt
Visitor
Wifi Error
Does not connect to Wi-Fi in any way
No se conecta a wifi de ninguna forma
2 REPLIES 2
Uliwooly
@Oppsttttt
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
I'm sorry to hear about the issue, but I have a few questions?
Have you tested different hotspots/WiFi/routers?
How about if you boot in >>> safe mode then try again.
Oppsttttt
Visitor
Wi-Fi does not connect to any antenna. I've done everything. the WiFi modem works perfectly with other devices
