Saludos, mi xperia M5 dejo de funcionar la bocina o alta voz, al principio considere que era un error de actualización, y realice una reparación de software con el programa de Xperia Companion, pero mi xperia siguió con el problema. ¿qué puedo hacer en este caso?
De antemano gracias
Regards, my xperia M5 stopped working the speaker or loud, at first consider that it was an update error, and perform a software repair with the Xperia Companion program, but my xperia continued with the problem. What can I do in this case?
First of all, Thanks
GT
Solved! Go to Solution.
Hi @JuanLopez30
Welcome to the community!
I have translated your post as this is a Global forum and all posts/replies must be in English
As you have tried a software repair and are still experiencing issues I would suggest contacting your Local support for further assistance. They should be able to help arrange an assessment and repair for your device.
Good luck
Hi @JuanLopez30
Good luck
The signal is not tight.
สัญญาณไม่ขึ้นคับ
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
