Sony M5 screen with problem
lmillert85
Visitor
Water got into my Sony M5. I took in an assist, and did the deoxidation.
It turns on normal, but the screen with the time of use begins to give problem and the lock (as pictured).
I took it again to the assistance, and they told me that the main board had been oxidized, and there was no repair.
I would like to know if there is any way to fix it (changing the LCD screen, touchscreen, etc.) or there is no way
1 REPLY 1
Uliwooly
@lmillert85
I'm sorry to tell you this but if there are issues with the motherboard, replacing any other part won't solve the issue; to make things worst, the motherboard it's the most expensive part of a phone, replacing it will cost you almost the same as a new phone.
