problem with reset
styler1
Visitor
problem with reset
Hello, did reset the phone and after that he can not establish a connection with Google at the initial setting, here is a screenshot http://prntscr.com/jc9qqj
and because of this does not fully include the phone
how fix this?
3 REPLIES 3
Uliwooly
@styler1
I don't understand the text on the picture, but it seems to be an issue with your google account, you will have to attempt to access your Gmail with a computer and if you have any issues, contact Google directly.
styler1
Visitor
After reset the factory settings  telephone on 4 step install he stop(cant install  reliabe connect).
Uliwooly
@styler1
is it the step when you try to enter your Gmail?
