My niece has locked my phone using a pin.Now she has forgotten the pin,so I now humbly request u people to help me, what I have to do now??!!!!!!!:smileyshocked:
Solved! Go to Solution.
If you choose 2. then
You have 3 options
1) use MyXperia
myxperia.sonymobile.com
or
2) android manager
https://www.google.com/android/devicemanager
or
3) SUS
You have 2 options
1. Keep trying, it might ask you for your Gmail password after 5 or so failed attempts
or
2. Do a factory reset, it will delete everything
You have 3 options
1) use MyXperia
or
2) android manager
or
3) SUS
thanks
thank u very very very very muchhhhhhhhhh............
i unlocked the phone
thank u again................:smileyyahoo:
Anytime
Go to settings-apps-all-album,force stop,clear data and restart the phone.
1) If you r still facing the problem then find out if there is a file named 'nomedia' in your album folder. If u find so then delete it and restart ur phone
or
2) go to settings>apps>all>media storage..........then click on clear data and clear cache
