HowTo recover your Sony Tablet S to the factory settings
jaylward
Member
Member
6,545  Views
This video will demonstrate how to perform a factory data reset. If you are having an issue with your tablet you should always try a soft reset by using a small paper clip and inserting it on the side where it says Reset. A factory data reset is the next step if the soft reset doesnt solve you situation.
