- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Sony BDV-E2100 subtitles problem
Hi!
I recently bought Sony BDV-E2100 and I have a probem with subtitles sync. When i watch the app netflix or watch a movie in USB the subtitles gets unsynced after like 5 minutes. They are correct at first but after 5 minutes unsynced. Cant understand why? When i watch the same movies on the computer och tv (without the suround system) it´s synced.
Anyone knows why?
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
The only thing that you can adjust in regards to sync is a setting called "A/V Sync". Unfortunately this is not going to help you as this adjusts the audio in relation to the video - nothing about subtitles. So the only thing left is a factory reset to be honest - which is worth a try.
Goto Settings > Resetting > Reset to Factory Default Settings
Once done, set up the system again and test.
Cheers
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi!
Thank you for the answer. Unfortunatly it didnt work. I watched the same movie as before on Netflix and on the USB and the movies subtitles are still unsynced.
What could it else be?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
Im going to suggest you do a 'live chat' with Netflix - leave the USB part of it out, but see what they say or suggest. It is quite possible that its a coincidence that both Netflix and USB have issues with subtitle syncronisations and the issue may or may not be related to each other.
But give Netflix live chat a go and see ?
In regards to the subtitles via USB - are you using a .srt file or is the subtitles encoded in the file itself - .mkv files??
Cheers
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hey,
I have the same problem. did you get an solution ?
Greetz
Els
