Sound bar turning it self off
Nirvanamadliz
New
I have the cbt60 sound bar and it’s worked fine up until now. I soon as I turn it on the lights come on and it turns itself off within seconds. It’s connected via a optical cable to the tv. I’ve done the usual unplugged it and checked all the cables.  Anyone any ideas please??
7 REPLIES 7
EdwinaU
Hi there,
Welcome to the community.
Can you let us know the full model number of your sound bar so that we can advise you?
Thanks,
Ed
Nirvanamadliz
New
Hi
its a SA-Ct608T
thanks
EdwinaU
Hi,
Thanks, we'll look into this for you and let you know what we find. Maybe some other members will pop into the thread with some tips too.
Best wishes,
Ed
Tenneen9000
Member
Hi Nirvanamadliz,
I am a bit confused here. Are you talking about the HT-CT60BT soundbar which has the SA-CT60BT as a part of it? If that's the case, Have you tried resetting the soundbar? You can find out how to do that on page 24 here.
All the best,
Tenneen9000
dougkay
Explorer
I too have the same model and same issue. The reset function mentioned has not worked. Is there a solution to this?
Bat_Rick
New
I believe there is something wrong with the hardware, reach Sony reps. and find the nearest repair center to your place, inspection is needed i guess.
dougkay
Explorer
