software
SOLVED
profile.country.en_GB.title
putupon
Visitor
software
where can i get a download for vaio media plus to use with pc and nas-z200dir ,the disc I have is only for vista I need windows 7
1 ACCEPTED SOLUTION
Accepted Solutions
tweety2b
Ex Commander (Was always on)
Hi,
Basically you go to :http://www.vaio-link.com/
then select your model you have and go to the download section.
In that section is a Windows 7 folder where you can download all drivers and applications that have been released for Windows 7.
If not available in that section you might want to check out the patch/update folder.
Cheers,
Nico
Nico Henderijckx
(ex-Sony employee - fanboy forever)
2 REPLIES 2
tweety2b
Hi,
Cheers,
Nico
Nico Henderijckx
putupon
Visitor
thanks for the info,I have just been informed that windows 7/media player 11 has the streaming built in and I clicked on the stream buttom paired it and it is now working great
thanks again
