RDP-X60iP with I-pod touch 4
profile.country.en_GB.title
jaburro20
New
I have bought an RDP-X60iP for use with an i-pod touch 4th generation.  I can't seem to get the sound to play through the speaker - all the lights are on and the i-pod works.  I am award that some models are not compatible but the i-pod touch 4 is on the box and the instructions as a compatible device. Any help would be appreciated.
1 REPLY 1
Convergence
Visitor
Hi when you connect your iPod does it charge? or is that also not functioning?
