HCD-MD373
profile.country.IE.title
Brayman
New
HCD-MD373
When the unit is powered up the CD tray slides out regardless as to what options are selected. If you close it comes out immediately whether there is a disc in it or not. To close the tray you must first disconnect the power lead from the mains and manually push the tray shut.
1 REPLY 1
HannahEd01
Hey Brayman, that's a 1999 model, I couldn't find any manuals for it. Try contacting then nearest service centre: https://locator.sony/en_GB/servicecenters/?zoom=5&latitude=54.29088&longitude=-2.37305https://locato...
